After more searching I turned this up posted by GrndZero. Can anyone confirm?
For the Driver seat:
svt pin 1: driver side-airbag signal: wire to driver seat harness pin 9
svt pin 2: driver side-airbag return: wire to driver seat harness pin 10
svt pin 3: not used
svt pin 4: not used
svt pin 5: seat heaters switched power pass-through: jumper with svt pin 11
svt pin 6: heated seats switched power: wire to driver seat harness pin 5 (green and red wire)
svt pin 7: seatbelt buckle sensor signal: wire to driver seat harness pin 3
svt pin 8: seatbelt buckle sensor return: wire to driver seat harness pin 4
svt pin 9: powered seat-height power: wire to constant power
svt pin 10: powered seat-height ground: wire to ground
svt pin 11: seat heaters switched power pass-through: jumper with svt pin 5
svt pin 12: seat heaters ground: wire to passenger seat harness pin 8
svt pin 13: seat track position sensor signal: wire to driver seat harness pin 1
svt pin 14: seat track position sensor return: wire to driver seat harness pin 2
For the Passenger seat:
svt pin 1: passenger side-airbag signal: wire to passenger seat harness pin 9
svt pin 2: passenger side-airbag return: wire to passenger seat harness pin 10
svt pin 3: seatbelt pretensioner switched power: wire to passenger
seat harness pin 5
svt pin 4: seatbelt pretensioner signal return: wire to passenger seat
harness pin 6
svt pin 5: heated seats switched power: wire to passenger seat harness pin 1 (green and blue wire)
svt pin 6: seat heaters switched power pass-through: jumper with svt pin 11
svt pin 7: seatbelt buckle sensor signal: wire to passenger seat harness pin 3
svt pin 8: seatbelt buckle sensor return: wire to passenger seat harness pin 4
svt pin 9: not used
svt pin 10: not used
svt pin 11: seat heaters switched power pass-through: jumper with svt pin 6 (red and orange wire to accy power)
svt pin 12: heated seats ground: wire to passenger seat harness pin 8(to black wires on switches)
svt pin 13: not used
svt pin 14: not used
