Yup, the sensor actually reads exact ethanol percentage to avoid incorrect timing. I wonder if it's possible to access this sensor via OBD2 or if I'm not mistaken, PIDS??. So that we can set up an app like Torque to see percentage. Would that be possible??
Sent from my SM-G900P using FF Mobile
I have not looked into the ability of the sensor to read actual % but I do know that the timing and fueling change when it does sense "E" fuel does not , there are only blanket adders for timing and fueling when switched to stock "E" tunes and the actual "E" % is not taken into account
People are getting to caught up in the "E" part of the fuel and you should be as much concerned about it crap gasoline added to it and its rarely ever 85% and almost never higher then 85 octane fuel added
" The research octane of ethanol is impressively high, which is a beautiful thing for high-compression and high-boost applications. However, its motor octane (the more extreme standard) is relatively low when compared to racing gasolines of similar (R+M)/2 octane. What this means is that E85 is highly resistant to knock but somewhat sensitive to preignition, comparatively speaking. (Knock and preignition are two different conditions: Knock is spontaneous combustion in the end gases before the flame-front can arrive, while preignition takes place before the timed ignition spark occurs "
Reading the above everyone says running E85 you add more timing isnt always the case and exactly what I have found tuning with PUMP e85
