The usage of mercury is not allowed to the toxicity... it is allowed within glass vials within some housing thermostats due to its impossible to break under normal usage.. in a vehicle the vials can rupture in a vehicle impact
the reason the ebrake light only flickers on level is due to the size of the Fluid reservoir when its level the float sensor sits low which triggers the light when on an angle again due to its size push's the float up making the car think it has more
theres 2 Reasons that cause the reservoir to run low of fluid
1. Brakes are excessively used which causes the brake system to store the fluid within the calipers/cylinders to keep the brakes pads/shoes in position
2. a line or the Caliper/Drum cylinder is leaking slowly
I find it funny when people say there running out of fluid top it off then find out a month later they are in dire need of brakes, take it to a backyard mechanic who doesn't open the brake reservoir and try to retract the cylinders back into there housing causing something to rupture or blistering a soft line (and people wonder what causes the spongy assed brake pedals)
