1 - 13 of 13 Posts
I just installed a set of silver stars and went to put the dust covers back on. its like they're damaged or to lose or something. they wont stay on. i've tired over and over again they are just too loose now. will this hurt my new headlights? [:(]
FF #1 Most Wanted
Are U talking about the one on the back of the HL's that keep air and water out of the headlight so you don't get condensation or water damage in your HL's ?
If yes, I'd go to the hardware store and try to find something that will fit.
Discussion Starter · #6 ·
yeah the ones that keep moisture and stuff out!
what would i find at the hardware store that could fit?
FF #1 Most Wanted
Look in the plumbing or electrical section.
Take one of the covers with you so you have something to reference.
If you can't find one, ask one of the people at the HW store if they carry pipe end covers or caps in your size.
Are they actually broken?? If you didn't break anything there's no reason they shoudln't just go right back on. I had a similar issue when replacing the headlight bulbs in the Escort, it felt like I was putting it on, but yet it was loose.
Turns out, I wasn't pushing hard enough to force the thing back in place; sometimes it's kind of a tight fit, that's how it keeps a tight seal against anything getting inside the housing. If it helps, take out the headlights (or one of them) and examine the fitting (with the red rubber) to see how it attaches to the headlight housing. Should be some kind of twist and lock type blades molded into the headlight fitting.
You have to push the bulb and fitting HARD against the housing and then twist to actually seat the fitting into the housing. Maybe this helps... [?]
Go to the dealer and get them replaced because they are defective. I had the same ones and they changed both headlights out with brand new ones
I just swapped out my headlights with LED bulbs tonight and the wiring won’t fit in the housing because of the giant plugs that came with the LED bulb (beamtech). My cover won’t fit because of the protruding cables so I left them off- I will let you know if anything happens. I assumed it’s going to be okay because there is a plastic ring that fastens the headlight to the housing and I am hoping the ring will act as a cover... then again, if it did Ford probably wouldn’t have made the covers. I will keep you updated- and if anyone here has a solution for my problem please link me or shoot me a reply.
1 - 13 of 13 Posts
