My engine was misfiring. I replaced the Spark plugs, It helped but the problem was still there. I replaced the boots on the coil plugs along with the springs that go inside the boots. I cleaned the connections with electrical connection cleaner. When I plugged the coil plugs back in I didnt plug them into the same spots, as in the one that was in the 2nd cylinder I plugged into the first cylinder wire etc..(Dont know if that matters or not). Now the misfiring has stopped and its running alot smoother except for one thing. If I hit the throttle smoothly, the engine revs up smoothly like it should. When I hit the throttle a little to fast, It sort of "bogs out" Like the engine doesnt want to rev up (Do you know what I mean by that?). What could be causing this new problem?
