1 - 10 of 10 Posts
Retired Focus Addict
I am going to be trading my TB for an aluminum head and I was wondering.. I can drop that head in right after I get it right there are no other parts I need right???
The only thing I am going to be doing to this head is port and polish.
what are you talking about? the stock head is aluminum.
Discussion Starter · #4 ·
I know the stock one is alumimum but I want to port and polish the head and I don't feel like being without a car for a few days so I thought I would buy a spare one so while that one is being worked on I can still drive my car... is that what you mean when you are telling me the stock one is aluminum???
Can the stock aluminum head be port n polished???
Yes. However, reading around here and on FJ you'll learn the Duratec head is very good in stock form. Unless you are pushing some really strong HP & TQ numbers the port & polish isn't going to give much value for the money.
Also, in another thread someone pointed out the steps work required to replace the head and I was suprised at the number of things I hadn't thought about -- it's not a quickie job.
porting and polishing is fine, but while you are at it, you should upgrade your valve springs, oversize your valves, and upgrade to high perforamce studs
also porting and polishing is usless if you don't over size valves
Sückn' n Blown
Removing the head while the engine is in the car isn't an easy task. You need to remove the crank pulley, possibly a bunch of the accecories, support the engine from the bottom, remove the passenger motor mount, removing the front cover, remove the timing chain, remove the timing chain guides, remove the header, remove the intake manifold, drain the coolant, remove the coolant hoses. Once the head is off, disassembly is easy. However, assembly isn't, due to the design of the spring retainer keepers.
You are looking at a lot of work for small gains on your current setup. I have a head right now getting a custom 3-angle valve job, but I have a whole new engine going in with a built bottom end. The 3-angle was recommended over the P&P; stating that even for my new engine, P&P won't show much.
I think its a 12% drivetrain loss on the mtx... so 175whp x .12 drivetrain loss = 21bhp loss = 196bhp total. even though your not in the 240+ bhp range id still say go for it while you have the parts and money. that way when you do a few more mods later on you wont have to touch the head. just dont get as drastic a p&p job. maby more like polish and valve job. well thats what I would do if I had the parts and extra bit of $$$
1 - 10 of 10 Posts
