FIXED AT LAST!!!
Now I can stop driving the minivan every day. LOL!
After swapping the alternator... it still didn't charge.
A few notes:
Removing the three passenger side motor mount bolts allows the engine to slide forward a couple inches making more room. It only takes a minute, and is well worth it.
The alternator heat shield comes off, then half of the plastic scoop comes off.
At this point, the main lug to the battery can come off, and the one bolt and two studs that hold it on come off. Then, it can be unplugged from the harness and removed from the bottom. All this is up on jack stands with the passenger side tire removed.
Anyway... It still didn't charge, so I had the old one tested, and it test JUST FINE... so I started checking wiring. I made a jumper from the main battery lug straight to the battery, and it WORKED. Therefore, the problem was somewhere in the cable.
I cleaned all the connections, and it charged again! Woo-Hoo!
At this time, since it was up on jack stands, I decided to install the 24mm H&R front sway bar that I bought about a year ago... before I realized the front K-member had to be dropped down, etc. Well, that took longer that expected, but we won't go there. lol
I then dropped the car back on the ground, fired it up... and THE ALTERNATOR WASN'T WORKING AGAIN!!!! AARRGG!!! It was now 1:45AM and I had to get up for work at 6, so I walked away, and finally wound down in time to get to bed at 3. lol
This morning, I traced it to the inline 175amp fuse that is made into the cable, and not changeable. I priced a new cable at the Ford garage, and it was $102! F-that! At that point, I smashed the plastic of the fuse apart, and saw two substantial ends that the copper 'pencil lead' element were fused to. The Ford garage had shown me one that looked like this...
so I put 2+2 together, and drilled out the lugs in the cable, and bolted it in place, and secured the new fuse with 1/4" bolts. Everything was covered with di-electric grease to minimize corrosion, and covered with conduit and black tape. It works great!
Now, about the front sway bar...
I had installed a 1" rear bar about a year ago when I bought the front, and it really tightened up the rear, but made the front feel comparably sloppy. (yes, I welded in supports where it mounts to the control arms)
The addition of the front bar made a HUGE difference! The car handles like it's on RAILS now! That wagon, with all it's extra higher placed girth NEEDED those big sway bars! That addition alone was worth all the hassle with the alternator.
Oh well. NAPA sold me the alternator at a discount for $170, a NAPA (Gates) belt for $23... so I've got around $200 in an alternator I didn't need, but it was a learning experience. Who knew these new cars had these big fuses in their battery cables going to the alternator??? My old cars never had that! Never mind the fact that they could go bad... intermittently! Oh well, next time... BEFORE swapping out $200 PITA alternators, I'll be making it a point to check the $10 fuse first!
Oh well. At least the sway bar is on!
