1 - 2 of 2 Posts
first and foremost.... i wish you the best of luck with your product. In the past two years, i have had to pull nearly 30 DUAL 7500's (the black one with motorized face, and the previous grey model with motorized face) and send back to vendor for R&R... both sides of the face usually doesn't retract and it jams.... so, good luck.
first, remove the two #1 phillips screws atop the radio
then, slide the cage from the radio.
slide cage into dash kit opening. you may need to slightly bend a side as the fit will be tight.
once the cage is in the dash kit, bend down some of the tabs around all four sides so the cage is SECURED to the dash kit...
now, slide the radio into the cage.
-john
SQF
1 - 2 of 2 Posts
