Originally Posted by iminhell View Post
^^Not sure I've ever seen that. Maybe in a rotary Focus, but not ours.
IIRC the motor engages when the key is turned on. So if you start the car then go out to see if the motor moved you might be fooling yourself. When you turn the key you should here kinda of a thud from the intake switching to the long runners, but it may be pretty quite, use a friend to make sure.
I did this with my brother...he started the car as I watched the DSI wire not move at all...
I think the culprit here is the Dual Stage Intake module or pigtail as they call it. The motor for the module or pigtail is possibly burnt out. The butterfly of the DSI probably moved a little as in tiny movement when you started the car and when you rev the car to 5k plus rpm it moves by letting go of the butterfly inside the Dual Stage Intake Manifold (this is probably the movement you are noticing). Or possibly the spring mechanism for the butterfly is getting stuck(very doubtful though because them springs have very strong tension) I know this because I have a SVT IM laying in the garage waiting to be installed.
Does the car feel like it lost a lot of torque at low RPMS but feels strong at high RPM? If yes, then the I am sure the culprit is the DSI module or pigtail as others call it.
