1 - 4 of 4 Posts
I've heard the European spec Foci with the wet clutch can handle more torque. Does anyone know how much exactly? Also, is there any difference in shift speed between the two?
*edit* I'm talking about the dual clutch transmissions
typically wet clutches hold less because the lubrication reduces friction, unless they stacked a bunch of discs.
shift speed is controlled by your foot/hand/synchros. a clutch will engage/disengage as fast as you tell it to. (unless worn or overpowered then it slips)
my guess on a stock oem clutch they will make it to handle 50%-75% more torque then the engine outputs. any major modifications ie. forced induction will probably require a clutch upgrade among other things.
wow I had no idea there was this much stuff going on with a clutch....so usa cars are dry clutches? meaning we control all that good stuff you just mentioned? sooo whats the benefit of the wet clutch?
I should have been more specific i guess, but I was referring to the dual clutch transmissions (Ford's "Powershift"), not manuals. The Euro Foci get the wet clutch with the diesel model. I'm not sure about their petrol model though.
1 - 4 of 4 Posts
