How old are your battery cables and your starter?
Original, as far as I can tell.How old are your battery cables and your starter?
On initial crank, voltage drops to 10.2 or so.You might want to do a voltage drop test while you are trying to start it. See how many volts you are losing.
Dont yet , easy way to check for Vac leak everywhere is get a Cigar and do a smoke test , if your not sure how call meI am taking a shot on intake gaskets, had Oreilly bring them to me at work today. I am also going to swap out injectors, as I already have some of those.
I did the cigar test, no blatantly obvious leaks. I’m grasping at straws here, at this point.Dont yet , easy way to check for Vac leak everywhere is get a Cigar and do a smoke test , if your not sure how call me
10.2 volts is not enough. Have the battery load tested.Original, as far as I can tell.
PCV parts came in today, going to change those soon like you suggested a few days ago. Nobody in town had them in stock. My PCV hose is collapsed mostly, if not all the way shut at the first bend by the intake. Would think it’d run rough if it was completely shut, but it needed replaced so I’m doing that after dinner.
Load tests good, is only a couple months old. Could be partially drained due to extended crank times. I am going to charge it over night and load test again tomorrow at work.10.2 volts is not enough. Have the battery load tested.
Sold it. Guy I sold it to swore he had it figured out, and sold it as well. Currently for sale by the 3rd owner after me.Sounds almost the same as my problem. Was there a resolution to this one?
That may be my solution too. My friend the used car dealer says the prices at the auto auctions are pretty ridiculous now.Sold it. Guy I sold it to swore he had it figured out, and sold it as well. Currently for sale by the 3rd owner after me.
You have vacuum leaks. The svt is pretty finicky and has a horrible cold start issue. Furthermore, no one wants to do the work involved to fix it.All this. And no one has found a solution? I just bought mine. Drove PERFECT for 6 days. I went to check codes because the PO welded the o2 bung in wrong spot to watch fuel trims, noticed the IMRC was p1518 p1520 so I inspected it. Determined it was bad. Dropped the car down off the jack. And started it, decided to run through some function test on the Modis and during idle control test the car died and would not start back. Smelt flooded, and now here I am reading you guys post and having a flooded car that I do not know what to do with.
They just whine and try to blame another component after they are told how to fix it. It doesn't cost more than $50 dollars to fix but alot of labor.All this. And no one has found a solution? I just bought mine. Drove PERFECT for 6 days. I went to check codes because the PO welded the o2 bung in wrong spot to watch fuel trims, noticed the IMRC was p1518 p1520 so I inspected it. Determined it was bad. Dropped the car down off the jack. And started it, decided to run through some function test on the Modis and during idle control test the car died and would not start back. Smelt flooded, and now here I am reading you guys post and having a flooded car that I do not know what to do with.
You are welcome.I pmed you. Thank you for actually replying and offering assistance at fixing this issue.
I have found that intake warpage at the throttle body boss and the iac boss cause dynamic vaccum leaks undetectable by smoke test. I file both bosses flat as well as sanding the bottom of the iac valve flat as it has a die cast body and the sealing surface is not flat.For the record, was this (quoting from your older post) the advice?
For my 2 SVT'S, replacing all of the vacuum lines and then putting new intake gaskets between the head and intake, retightening the intake couplers eliminated my cold start problems.
When we pulled the head on ours (bent valves) last summer, those intake gaskets were indeed flat and hard.
I replaced a lot of small things including those, PCV line, vacuum hoses and front O2 sensor as well as the distributor connector. We never had any starting issues but we DID have an occasional "half warmed up" stall that has never recurred.
