1 - 14 of 14 Posts
hey I have the draxxes headers on my 05 2.0l they give a nice noticable boost in power in second gear. Maybe a little expencive but if u put them in urself its not to bad
I think it is the only header that you can keep all of the stock connections. It looks to be a good header.
It's the only one that has the PZEV tube and 3 sensor holes. F2 has multiple sensor holes.
Also, we only have one header.
BodyKits=PantiesDrop
yes its the air pump and is not necessary. it is there to warm the mani-cat (cat/exhaust manifold combo) during start up and if you have a header then you have no mani-cat and therefore it is not necessary. you can just leave the rubber hose open, it will do nothing bad or good.
Or you can get a Cossie manifold and rip the rest of all that junk out like Evan!
I have a draxxas header on my 05 duratec motor it has the 3 holes for the 02 sensors and all are hooked up but i now get a check engine light. Do i need to buy a tuner to fix this problem?
Force-Powered Focus
they dont make this anymore, right?
Correct.
1 - 14 of 14 Posts
