In a automatic, does it help your time if you turn off the Over Drive? Iheard from some people it does, and i notice it increases RPM's but having overdrive off is engine slowing, so how does that make you go faster?
1-2-D is so you can keep it in a low gear for snowy or dangerous conditions, especially when dealing with inclines, allowing for lots of engine braking. Manually shifting an auto will kill it, but it's your tranny, not mine.N2O Focus said:I would say shift manually, but if it is actually true that in D is shifts at redline *** then stay in D. I would try both ways and see which is better for your racing. Cars would not be built with a 1-2-D unless you would be able to make manual shifts, especially on a focus. Who would ever need to hold first gear in that car for daily driving? Manually shifting the car is not going to hurt it if your just doing in at the races, but if you are shifting this way everyday of course you are going to do some damage.
The problem with what you are saying is that it is the same as manually shifting and if you live in those types of conditions then you would be trashing the tranny. But it sounds like if you live in bad weather areas and use 1-2-D then it would be the same as manually shifting at the track once or twice a month.OandAWOW said:1-2-D is so you can keep it in a low gear for snowy or dangerous conditions, especially when dealing with inclines, allowing for lots of engine braking. Manually shifting an auto will kill it, but it's your tranny, not mine.
