1 - 2 of 2 Posts
Hey everyone, I am new to this forum and I am in need of some advice. I have been chasing an issue with my 2012 Ford focus dps6 transmission. It physically will not engage any gear but it will select what gear I move the shifter to on the screen on the gauge cluster inside the car. I plugged a code reader in and it had code P07A3 for friction element A stuck on and P287A which is clutch B stuck engaged. I did try to swap the shift motors and didn't have any luck. But after I swapped the shift motors and cleared the codes. They didn't come back. Car still won't engage any gear. Thoughts?
TCM module trouble. Happened to mine. Ford did not replace mine however, just reprogrammed. You might get it replaced by Ford under the warrantee extension on the TCM.
1 - 2 of 2 Posts
