Then not EGR UNLESS it's possibly stuck at valve itself and not that common on these. But possible.
Most (not pointed at you of course) haven't figured out yet the two major idle problem differences. One, just won't idle or does for a second or minute then dies-but idles correctly and EVENLY if throttle manually brought up a bit, and two, ERRATIC idle or misfiring doing it, engine shaking around. Two different directions there. The work and money spent can often be halved by determining which one and only the OP can do that. But no one ever spends two seconds thinking about that (sigh).................
Even idle............IAC, TPS, TB bore clogged with deposit
Uneven idle.........vac leak, ignition quality, pcv leak, unmetered air
MAF probably goes in the uneven column but could be either I'd bet.
Vac leak can mess with your mind, small enough to where it still has idle trim fuel left and the idle goes too high, then as it runs out of trim fuel drops back and then begins to misfire.
