1 - 10 of 10 Posts
Discussion Starter · #5 ·
Yeah I was wondering if this would actually work or not since it still places the 02 sensor in the stream of the exhaust gases. I just didnt want to cut my 02 wires. I've done it before on my spec V when I installed a header.
By the way do I have to lengthen the wires to install a FS header or will they reach?
I've never done a FS header install, but with the newedge cheater you won't need to cut the wires, it comes with plugs so you just plug it in between the sensor and the wiring that runs to the computer.
Taking two 14mm spark plug anti-foulers and stacking them is all those Ebay things are.Yea,they will work as the oxygen sensor has to be in the stream to accurately record data.Cheap trick,but it works(I've done it myself)
Discussion Starter · #9 ·
So thats what the things are. I don't believe it will fit on a focus with a race header. I found the pic of the header installed on Focus sports web site. It looks tight in there.
Interesting I might try those things on my Delsol. Where can I locate those Spark plug anti-foulers, any auto parts store?
This definetly won't fit on a FS 4-1 header, there is NO room at all. what I did was remove the second o2 all together since its disabled in the SCT tune. Plugged the hole witha bung, much cleaner.
1 - 10 of 10 Posts
