1 - 2 of 2 Posts
Hi All,
Was looking for some help/instructions on how to remove the rear passenger door as wife messed it up pretty bad it needs replacing. Not the inside panels etc, the whole door.
Any help would be appreciated.
Thanks
Meh.
Don't know the specifics on your generation European Focus but generally it's simply two hinges that need to be unbolted from the door, and one wire loom that needs to be split. On the first gen Foci, the loom has a simple twist fitting that you grab, turn, and it comes right apart; I assume yours will have a similar setup.
1 - 2 of 2 Posts
