1 - 4 of 4 Posts
Anyone else notice their door mirrors making a high pitched squealing noise when at freeway speed?
I've tracked the noise down to the air gap between the door mirror and mounting bracket where the mirror pivots.
I've experimented with taping up the gap, that quiets the noise down. However, I'm still searching for a less visible solution. Next I tried some foam rubber pad in the door mirror pivot slot, that helps but there's still surface area for the noise to develop. I've thought about using some clear silicon cocking in the slot to fill it up, but that sounds a bit extreme.
Anyone have this problem and found a solution?
1 - 4 of 4 Posts
