The cars have a very common problem with the wiring harness that runs into trunk lid, they fray the insulation to crack then it falls off to commonly short other wires or ground out to same. You have to cut away the outer covering to see the individual wires and do it where the harness flexes the most where it goes into lid hole as you raise and lower the trunk lid, that will point you to where to begin your search. You'll find bare/cracked wiring somewhere if so.
Which button you hit tells you likely what is messed up. The latch assemblies can do it too if the power to work them has to go way up due to old part with high resistance built up in it.
