1 - 3 of 3 Posts
So my dad's 2002 Focus (manual doors) passenger door stopped opening. It was loose as hell but could still be opened from the inside. I opened up the door and looked behind the trim. Tried the handle and found the culprit.
This is what's happening. This rod connected to the handle(marked in red):
When opening moves down but then as it pushes on the metal section for the latch, it slips through. I bent it out just a tiny bit (more to the left) as a temporary fix, so it still slips on the first try but opens on the second.
Here's my easier explanation (sorry if the sketch isn't too good):
Wanted to know if anyone ever experienced this and fixed it or if someone just knows everything Focus and can help me out.
Did you ever get this issue solved, having the same problem and cannot find a replacrment manual assembly anywhere
1 - 3 of 3 Posts
