1 - 9 of 9 Posts
Wiring got ripped out of the clip and I don't know which goes where. Anyone know?
Do they sell new pins and the clip? I couldn't get the old pins back out to re solder.
one of the wires is going to be a constant live power for your map lights, one is a ground, and one supplys power when you open your doors/turn on intrerior lights. not sure if this helps, but i dont remember from when i did my rear interior light, multimeter will be your best friend in this situation! hope this helps at all! also not sure where abouts you live, but here in northern ontario, you could probably pick up the connctor nd pins at maslack, autozone, or napa!
I already metered them. I just need to know what wire goes to what pin for the connector.
Perfect! Thank you so much!
Discussion Starter #9
Finally got around to extending the wiring. Good to go now.
1 - 9 of 9 Posts
