1 - 7 of 7 Posts
After an engine swap(put a different zetec in), I have an extra plug that I cannot identify. The car seems to run fine and does not throw codes.
This is a 2002 ZTS Focus, engine from a 2000. 5-speed if that makes any difference. The wire runs from passenger to driver side along the top of the radiator(it has clips to attach to the crossmember), and ends near the drivers headlight.
White 2003 zx5 autotrans zetec, grey 2003 zx5 standardtrans zetec, grey 2004 se standardtrans zetec
Are your fans running? Might also be for fog lights?
I just had the same problem sensor right under the trans mount on top of trans, took 3 days to find it, I dropped my 10mm when putting battery box back in found socket sitting on top of sensor connector.
1 - 7 of 7 Posts
