1 - 18 of 18 Posts
I posted this in an old thread, but wasn't sure if people read it since it was pretty large, and the subject was about something else.
My question is, when you hit the remote start, do the doors lock if they are unlocked? Looking for people with keys and not push button if possible, since I don't know if they work the same way. I just installed the factory remote start and wondering if I have everything hooked up correctly. Right now, my doors DO NOT lock upon remote starting.
Thanks!
The PowerCode 1-way on my Escape did lock the doors before it started.
The 24-pin harness has two blue wires both for door lock outputs, they should be #2 and #24. Double check that you're using the right one. Pin #2 will only work if the alarm cartidge is installed, pin #24 is for the remote start cartidge.
just for everyones info, there is no factory installed remote start option for the focus...only a dealer installed option. The dealer unit and remotes DO have the ford logo and are MOSTLY plug and play.
to answer the original question, yes...if your doors are unlocked when you HOLD the remote start button the doors will lock, then the car will start. And when you hit the unlock button on your key to unlock the doors, the engine will shut off.
Not sure you are right here. Pretty sure mine was factory installed and I know I didnt pay extra for it.
Seems it was installed at the factory.. At the FordEtis site this is my feature list... See bolded.
Minor Features
Charcoal Black Interior
Torino Leather (H-L)
Less Front Door Sill Protection
ACC Media Hub 2XUSB+AV+SD Slot
Less Interior Pack
With Hill Launch Assist
My Key
(-) Version Packages
Michigan Plant Built
Less Exterior Protection Group
Less Appearance Group
Titanium Badge
Less Dress Up RSO
Feature Content Group 1
Less Decal
For Normal Temperature Zones
With English Language Label
Owner Hand Book Pack
Less Tyre Repair Service Kit
Power Front Windows One Touch Up/Do
Power Rear Window One Shot Up/Down
Grille - Upper Blk Msh/Chrome Surnd
Mini Overhead Cnsl W/Sunglass Bin
Console - With Closed Bin
Int Environment Clr-Charcoal Black
Int Feat Colour - Charcoal Black
Less Floor Mat Kit
Front Floor Carpet Mats
Rear Floor Carpet Mats
With General Stowage Box
With Illuminated Sunvisor - Drivers
With Illuminated Sunvisor-Passenger
With Aluminum Interior Door Handles
With Load Area Cover
Less Decklid Liner
With Load Floor Carpet
Grille-Lower Surround Hgh Gls Black
Rocker Panel Moulding -Cladding C/K
With Bright Door Frame Moulding
With Rear Spoiler
5 Door Saloon
Dual P/Heat/Signal/Pud Lamp Mirror
With Body Coloured Exterior Mirror
With Driver Seat Back Map Pocket
Passenger Seat Back Map Pocket
With Front 4 Way Headrest
With Electric Driver Seat Recliner
With Two Piece Rear Seat Cushion
With 60:40 Split - Folding Rr Seat
Rear Centre Armrest With Stowage
With Drivers Manual Lumbar Support
With Drivers Heated Seat
With Heated Passenger Seat
With Driver 4 Way Pwr.Seat Adjuster
Less Fuel Economy Pack
Body Coloured Exterior Door Handle
Key Combination Pack 2
With Leather Gear Shift Knob
Less Door Entry Remote Control Unit
Keyless Entry/Start - Passive
Capless Fuel Filler Without Lock
With Int. Rear Window Wiper/Washer
Less Sun Roof
Less Bodyside Accent Stripe
Front Bumper - Painted Body Colour
Rear Bumper Body Coloured Plastic
Less Front License Plate Bracket
Belt D & P Fr 1 & 2 Row/D Kne Bag
Tether Anchorage Restraint-Style 2
Spare Wheel-22.5 X 7.5
7 X 17" ET 50MM Alloy Style 2
Limited Service Mini Spare Tyre
Less Wheel Covers
With Kysor Radiator Shutter
Less Immersion Heater
Standard Electric Starter Motor
With Remote Starter
50 State Emission Requirements
PZEV Evaporative Emission
Touring Suspension
3.850/4.278
2.0L Duratec DI TI-VCT (160PS)
Single Exhaust
Mechanical Hand Operated Park Brake
Standard Duty Fr/Rr Calp And Pads
With Rear Disc Brakes
Brakes-HLA/ESP/TC/ABS
Normal Fuel Fill
Less Full Vehicle Cover
Less Tape Stripes - FIA
Select Shift Tech (SST) W/Pad Shift
With Pollen Filter
With Lead/Unleaded Fuel
Standard Foot Pedal Pad Design
With Electric Power Steering
4 Spoke Leather Steering Wheel
With Speed Control
Conventional Instruments - Level 3
With MPH/KMH Speedometer
With Trip Computer
Less Instrument Gauges
With Compass Display
MFD TFT Touch Screen With Nav
With Message Centre
Navigation Data - N America/Mexico
With Perimeter Anti-Theft
With Rear Parking Aid
Less Front Parking Aid
Less Automated Parking System
Standard Duty Battery
With NAAO Radio Frequency
Less A/V Jack
Sgl Tun/Sgl CD W/Sdars/HD LXF
ICE Feature Pack 25
Branded ICP/Mini EFP
10 High Series Speakers W/Subwoofer
Less Cell Phone Interface System
Sync II With Navigation
With Steering Wheel Radio Controls
Less Smokers Package
With Power Point Plug - Rear
Rear View Camera-Fixed
Less Style Pack
With Auto Headlamps
With Black Fog Lamp Bezel
With Halogen Headlamp
Less Daytime Running Lamps
With Front Fog Lamps
With Black Headlamp Bezels
Multi Colour Ambient LED Lighting
Less Footwell Lights
With Header Mounted Map Light
With Front And Rear Lamp Bulb
Tail lamps - Level 1
With High Mounted Stop Lamp
With Automatic Headlamp Control
Spirit Blue
Generic Country Group 1
BV61-5310-NG* Left Front Coil
BV61-5310-NG* Right Front Coil
BV61-5560-NG* Left Rear Coil Spring
BV61-5560-NG* Right Rr Coil Spring
Outside Air Temperature Present
6 Speed Auto Transmission DPS6
Focus (C346N)
Series 66
(+)"USA"
(-) GVMT Service Administration
(-)"CDN"
(-)"GU"
(-)"BZ"
(-)"BS"
(-)"KOR"
(-)"AW"
Less Fleet
Beast....what year is yours? I have a SEL, and I work at the Michigan assembly plant and im like 99% sure that at least through 2012 they werent factory installed...maybe the post 2012 Ti are different.
2014, built 7-10-2014. Funny thing is, it was not mentioned ANYWHERE, not on the window sticker, the dealer didnt mention it. I didnt even know I had it till I started wondering why my fob had that 2nd 2X symbol on it.
My key fob looks like this... http://www.ebay.com/itm/New-Oem-For...s-Fob-Transmitter-Uncut-Blade-5-/310742298398
Hmm that is decent FOB for key + standard FOB + Remote start FOB all in one. May buy one for myself. Don't like having two different fobs.
BTW, I have a 2012 SEL. Installed bidirectional Ford remote start myself after buying it from partscheap.com, so I'm not sure if 2012 SELs had remote start option. Didn't see any with it listed for sale when I was searching back in 2011.Also, even if factory installed, you can reprogram the remote start to not shutoff the engine when you open the doors. This I know is applicable for non-push start cars with key starters. Not sure about Push-button start cars.
Mine does not shut off when I open the doors, I just get in hit the brake and hit the start button on the dash and I am ready to roll. :)
Thanks!
Just verified my 2012 SEL does lock the doors upon remote start. I have keys with seperate remote dongle. I ordered the car with remote start, though it appears the remote start was installed by the dealership. The antenna is mounted on the windsheild hear the mirror. This remote start has the furthest range of any one way remote start I've ever had.
can you send a link to getting to programming mode for the starter? I hate the auto shutoff when I unlock the door. And im pretty sure no 2012s had factory installed remote start...i could be wrong but im almost positive....
My 14 has the same fob as Beast posted. Factory installed I assumed. Actually I would've thought all of the push button Foci had this fob.
I'd hate to bring up an old thread. But I'm debating whether it's worth it to get the OEM Bidirectional remote start. Total I'll be looking at is about $460 installed. Don't really trust aftermarket systems. A couple coworkers have aftermarkets and they broke after a few months.
Help please?
Help please?
Up to you really, its more of a convenience feature. It is nice to get into a warmed up or cooled car though. Will be nice to get it running when its covered in ice and snow too to get the ice loosened up without having to go outside. Wish the damn heated seats would warm up though. Not sure if the aftermarket config would not turn them on though. The factory version sure doesn't.
I bought my 13 used, it was a lease car that was actually owned by the dealer's mechanic. Anyway, it has the installed remote start and I really like it. That was one option that I really wanted on the car I got.
I did have an aftermarket one installed on a car that I owned back in the late 90's but I paid pretty much the price that you posted, but that included a full car alarm also.
1 - 18 of 18 Posts
