1 - 6 of 6 Posts
do YOU have an Audiophile!? **UPDATED**
I have a 2004 SVT with the audiophile package among other things. I bought it about three weeks ago.
the stock amp is dead.
i just bought another audiophile amp from a newer focus which supposedly puts through the same amount of power.
it's quite a bit smaller
can you guys let me know if all the cables are there that need to be? I tested volts into the amp and I got 12.5 and I testes them out and I can't get a reading on either amp. do I need to change the wires around for the newer audiophile amp?
Here are some pictures that I hope can help.
thanks!
[:)][:)][:)][:)][:)][:)]*UPDATE[:)][:)][:)][:)][:)][:)]*
so I met up with Willybos of the forums here and i tried out the new amp and it works totally fine. I am thinking that the previous owner had an aftermarket set up and didn't properly wire the sub back up. So this means that I actually might've had a working amp all along! d'oh!
Is there anyway I can check if my wiring is proper?
PROBLEM SOLVED
I just got the car back from ford. The electrician said he had to have a ford engineer come to the dealership and help him out.
It turned out to be some bad wire between the HU and the amp. two wires were not putting a signal through.
So for the first time since my i bought my car a few weeks ago, i have bass!!! yay!
1 - 6 of 6 Posts
