Well I've had a few sets of cold cathode lights laying around. (ha ha I bought them for my scooter to use as an underbody kit so I could look cool at night...lol).
Anyways I decided to put a couple under my dash tonight. I hooked them up to my dimmer knob on the headlight on off switch. Here's how I done it.
Tools Used:
7mm and 5/16 socket
Electrical Tape
Zipties
12v Test Light
Wire Splice Clips
14 Guage Wire
Crosstip Screw Unwinder
Wire Crimper/Strippers
x2 12" Cold Cathode Lights (Green)
1. Take off the bottom panel under the steering wheel. (4 bolts 5/16)
2. Remove the A/C vent and then unscrew and remove the small panel (1x 7mm bolt on the side).
3. Remove the light switch assembly (x3 Crosstip) and then disconnect the wiring harness.
4. I used my test light to find wire that controls the dimming of the interior lights. It is the upper left Orange/Blue wire.
5. Just splice the power for the CC lights into this wire, ground and enjoy!
Now the only problem I ran into is that when I first turn on my headlights the guage cluster doesn't light up, only the needles. I have to turn down the dimmer, and then turn it back up to get them to work.
Also once the guage cluster lights are on, the light that lights up the odometer will not turn on.
Maybe someone could help me out on this one. I have no idea. Everything is grounded well, and all connections/splices are fine.
Here is a pic from the back seat.
[thumb]
Tools Used:
7mm and 5/16 socket
Electrical Tape
Zipties
12v Test Light
Wire Splice Clips
14 Guage Wire
[thumb]
