1 - 3 of 3 Posts
I've got a 2014 Focus Se and i'm looking to convert the rear drums to discs. Does anyone have advice on where to get kits, or any advice in general? Thanks
There are a few threads here in the past for MK3 drum to disc brake conversion. I am trying to do the same mod myself and didn't find the threads as helpful as I thought. They are a little older, the photos aren't all that, and the written description doesn't help me to understand the process.
Forgot to add, there is a rear brake kit for the RS from Ford Performance that can be installed:
The hardest part imo will be removing the drums. Some of the threads I read mentioned it was difficult to do. There is a bracket underneath it that is for mounting the caliper. After that, I'm assuming you just put on the rotor, caliper & pads, connect the brake lines, and then bleed your brakes.
Supposedly there may something that has to be done electronically to the car's software since there is a difference between the drums and discs?
1 - 3 of 3 Posts
