Performance is not bad, but things have gone wrong that should not have for a car that has only 108K, particularly the ABS/TC control module. According to the mechanic it has to be replaced in order to fix the traction control. Apparently the ABS is not supposed to be working when the light comes on, but I definitely felt it working last winter when the TC, ABS and Brake lights came on. A new module is $903CDN + installation, which includes bleeding the entire system as I presume the unit includes the HCU, as it means disconnecting all the lines to re & re the module. I've had it with NA built cars - my next car will definitely be an import.
