1 - 4 of 4 Posts
ok i know there is a how-to on how to turn your fogs into your daytime running lights but that's not quite what im wanting. i'm wondering if anyone know how to direct the daylight signal to something else, say like maybe the halos on hids.
if no one knows how then it looks like i'll be doing a how-to write up when i get my lights in.
Discussion Starter · #2 ·
?? no one has any clues
so, if you read up on the DRL fog mod, you might notice that it is very similar to the regular fog light mod, but with a wire heading off to a third location (normally, it jumps across to the DRL relay). so if you wanted your DRL as somthing else, you just need to wire it into relay 12. in the same slot as what was used in this DRLfog mod diagram
does that make sense? it does in my mind
Discussion Starter · #4 ·
yeah i think i got ya.. once i get my new lights in (once my refund hits) i'll try it out and put in a how-to for what i want to do.
my only question is from what i understand the lights use the same circuit.. just with DRL the power isn't full power.. then you hit the switch and it gives it full power.
1 - 4 of 4 Posts
