1 - 9 of 9 Posts
I've got a 2003 ZX5 with stock rims and stock 205/50/16 rubbers. Is there any possibility of using a different sized rubber (even a 55) on this rims without issues? The cost of that sized tire is quite a bit more than the more 'traditional' sizes.
Thanks in advance!
Any issues with handling or tire wear using a different aspect ratio (a 55 or a 60)? I do mostly city driving to and from work with some highway traveling. No agressive driving at all; I pretty much drive like a granny.
Shiroi kabocha
205/55/16 is about the max that you should run on the Focus, any taller and I doubt that the fitment would be very good. Remember, if you get bigger tires your Focus will look like a 4x4.
The 205/55/16 I wouldn't mind purchasing. For whatever reason, the 205/50/16 are "special order" at most of the places I've called in the area and quite a bit more $$.
Adam
Try wal-mart, if you have one around your area. ^^ Not all bigger sizes are less $$$ I work at a wal-mart TLE and there are many viva touring that are 205/55/16 and almost 100 each. I got 205/50/16 general exclaim uhp for 85 each. Just try around and see what you can find!
Shiroi kabocha
You can always order tires from TireRack or DiscountTireDirect as well, that way you get the good price and they are shipped directly to you.
TireRack has tires in 205/50/16 starting at $59.00, and 205/55/16 starting at $64.00.
DiscountTire has 205/50/16s starting at $61.00, and 205/55/16 starting at $66.00.
Discussion Starter #9
I had thought about tirerack but I'm in Canada so by the time I pay customs and duty it doesn't work out to be such a great deal.
So the consensus seems to be I could put some 205/55/16 on without any issues?
1 - 9 of 9 Posts
