I'm switching to 10w30 hm mobile 1 and wanna know if there's any difference.
Just keep running the regular Mobil 1 & your good.I'm switching to 10w30 hm mobile 1 and wanna know if there's any difference.
HM oil wont fix a leak or burning oil, once a gasket/seal is bad the only way to fix it is to replace it. It may provide a temporary band aid or slow a leak but don't count on it to fix the problem.Do you leak / burn any oil?
If no, then I wouldn't even consider one
I agree. I have a vehicle that leaks a lot ... I just add oil when it needs oil.HM oil wont fix a leak or burning oil, once a gasket/seal is bad the only way to fix it is to replace it. It may provide a temporary band aid or slow a leak but don't count on it to fix the problem.
125k miles really isn't that much, if your burning oil/leaking oil fixing the problem would be more helpful than putting HM oil in it and hoping for a magic fix.
And that's a point that many people overlook...it depends on where you live and drive.Guess it's not an issue in Florida, but 10w-30 is also a lot slower to start pumping in the extreme cold .... like here in NY
