1 - 11 of 11 Posts
I'm replacing my wheel bearings, many other things and cleaning everything before reinstalling. Well I sand blasted the abs ring since it was nasty(see picture), however the ring is rubbed thin on one spot. I think the blasting gloves rubbed this part thin because I didn't really blast the magnetic area.
Does anyone know if the magnetism of the ring makes the abs work or the magnetism of the ring plus these ribs?
I'm hoping I don't have to buy new rings since they cost as much as an already rebuilt hub.
RIP 02 SVT 0209
it should be ok , the new ones are smooth now they dont have the lines on them
nah it looks fine just clean it real good with soap and water, and also clean the sensor tip real good too
Should I use soap and water for the sensor as well or something like maf cleaner? I'm ignorant to how sensitive sensor are and error on the side of caution. Thanks!
Moved to Brakes, Suspension & Chassis
Soapy water doesn't hurt anything....
Discussion Starter #9
Just got the car together and no abs light. Took way longer than expected to finish everything. Thanks to everyone for your input!
Dang - it all worked!
Tx for posting that up, closes out the thread nicely.
Discussion Starter #11
Thanks again! I know I always appreciate being able to read the follow to what finally happened. I'm excited everything finally came together after the car being on jack stand for over a month. Here is a picture of rear wheel after assembly.
1 - 11 of 11 Posts
