I'm a few thousand miles shy of 100k miles on my 2000 ZX3. I was having terrible highway speed vibration, so I took it in to NTB and they noticed some pretty bad diagonal wear on my rear tires. It was so bad that I was shocked I never noticed it and it makes me think that the tires were not rotated properly.
Anyway, the NTB guy recommended that I replace the shocks and struts as well as the tires. New tires solved the problem, but do the shocks need to be replaced or is a diagonal wear pattern on the rear tires a common wear pattern if the tires aren't rotated frequently enough? The shocks and struts are still OEM btw.
Also, I've found the few posts in the forums that talk about a TSB for inner edge tire wear and an SSM for diagonal tire wear that recommends just adjusting the toe on the rear tires.
So, bottom line: should I be replacing the shocks and struts?
