How much do these dent removal guys genrally charge? I have about 3-4 little dents on my doors I'd like to get removed. Will it ever really look right with out painting it?
My vent selector and temperature selector are really stiff in the summer time. It's been like this for a few years. Works fine in the winter.
Well this morning it was stuck on defrost and I tried to switch it to face. It wouldn't move. I guess I forced it too hard and I think it broke. The...
Hi can anyone help I've just bought a focus 1.8 sport diesel tdci. Over all happy with the car but the previous owner has put a straight through exhaust on it, every time you start the car and drive all you can smell in the car are diesel fumes any suggestions would be great
The battery light comes on with ignition on and turns off when the engine is started but the battery is not charging and the battery drains down. After charging manually, voltage is about 12.8v. With the engine running , the voltage does not increase ( should be around 13-14v), I have...
104,000 miles on it.
I added a switch above the cigarette lighter to turn it off when I get out of the car, and replaced the cigarette lighter because it didn’t work.
What do I do now? I’m assuming I need to replace the stock plugs, I’m planning on doing it Friday and replacing them with...
Hey guys, I've got a little issue with the blower motor in my zx3 hatch. I've replaced the blower motor resistor and I'm still popping my fuse in the box under the hood. The car did sit for about 2 months and the blower had worked before it was parked. I'm stumped. Could the blower motor itself...
