1 - 5 of 5 Posts
Dat boxer rumble
Is that a vinyl wrap?
If so, you will need to remove that wrap and use a heat-gun to warm up the dented area, then you can carefully push it out from behind. it wont be perfect, but it will be better than it is now. Be careful not to overdo it, you can crack the paint (if its not already)
The dent on the rear quarter panel is more serious, unlikely you will get that out without repainting.
Discussion Starter · #5 ·
Yeah, I plan to bondo/sand/paint that bit. When the guy before me put the vinyl wrap on, they bondoed over the key hole and the assembly is fried. What ios the name of the key assembly so i an order a new one. Thanks for your help!
1 - 5 of 5 Posts
