1 - 11 of 11 Posts
Ok my car is an '02 MTX. Here is a list of mods so far:
Switch to Mobil 1 fully synthetic oil
Switch to Bosch platinum 4 spark plugs
Focus sport 8mm wires
Focus sport underdrive pulley
Volant Air intake
Volant Ram air scoop
Steeda 65mm throttle body
Custom 2.5" cat-back exhaust
OBX 4-2-1 Race Header
Tru-Bendz 2.5" Flex
Removed Cat.
Now The only two (or three really) other things I want to do is cams/cam gears, and the SCT chip. I wanna know which one to do first. I was thinking I should do the Cams and gears first so I don't have to have the Chip re-burnt... Howevere I could always have an extra program burnt and then switch to it once the gears and cams are installed? Any Suggestions? The only other thing I would like to know is this... When I do cams and cam gears I'm probably gonna do the gears first (probably gonna do the kent cams from focus sport.) Then I'm gonna do the Focus Central stage 2 cams from Mcnews. Does this setup sound good? I wanna keep it drivable because it's my daily driver, but I also want more power.
i wear no pants
yea get the cam/cam gears. if you wanna save a little money and get the cam gears from zx2racing.com they have em for 40 a piece. they are good quality. the best daily driver cam is the ford racing stage 2. they are 345 from mcnews.
Get the tuner, it will be like night and day of diference, if you get a good tune.
May I recomend Wayne from HIA.
i wear no pants
well what i would do if i were close would install the gears and cams your self, then order the chip then get a dyno tune and get the gears tuned. that way your getting the most out of the motor.
Discussion Starter · #6 ·
good point... I know I could do the gears.. they don't look to hard to install and then just set them at 0. But from what I've read the cams can be a bitch, is that true? Are they just drop in or is there other modifcations needed?
thfc1799 said:
oh and if i bought 2 from zx2racing can they fit exhaust and intake or will modification be required?
No modification required, good quality and great price. Been running them for over 7 months now.
i have the frpp 2's (cam gears at 0*i, 0*e...still) and im impressed but i was expecting more...i would prolly say go w something slightly more aggressive...i plan on switching them when i eventually get an frpp head
1 - 11 of 11 Posts
