1 - 7 of 7 Posts
Has anyone changed the light bulbs behind their speedo? Wanting to change mine to blue so that it matches my headunit and basically looks clean and well good!
If anyone has done this what are the bulbs needed to change over?
I have a 2003 Focus Zetec.
Old Phart
Moved this to the MkI Interior mods section.
You'll find info. on changing colors/adding lighting etc. in this section.
Cheers
ɔᴉʇɐuɐℲ snɔo&
I have done it :)
2 ways you can do it.
You can buy a new faceplate from one of the sellers on here (starfuryt550 is awesome!)or from metalmonkey.uk (mine is from Metal Monkey)
Or you can take your cluster apart and peel off the plate and sand off the green film.
Both ways will require you to take the cluster apart (including pulling the needles off) and you will need blue LED lights (or lights in the color of your choice) You'll need 3 194smd bulbs for the best quality. I get mine from superbrightleds.com
Starfuryt550 did the rest of my interior lighting conversion, just not the cluster.
Pyronisa that is amazing!! That actually looks awesome!! Exactly what I want! Cheers mate, appreciate that!
1 - 7 of 7 Posts
