1 - 4 of 4 Posts
While driving my car shut off and wouldnt turn back on, its a 2007 Zx3 5-Speed
i noticed the Check gas cap, and Battery light was illuminated. I have Dashs
------- where the miliges information would be.
i read its a common problem so i cleaned the negative battery grounds with a wire brush and dielectric grease, also checked all the fuese and greased all the main connectors in the engine bay and the connecters to the pcm.
i did all this with the battery unhooked and still nothing.
any help is appreciated.
FF Affiliate
Only a few things will caus there , there is a black/yellow or black /blue wire on the ground cable at the batt or beside the batt , clean those connections good
On the firewall fuse box there is 2 black diods look like fuses , swap them and see if it will start
Or some how you set the PATS
I would start there
I've checked the ground connections clean and they are good to go. The fuses tho I'm not to sure do you have a picture of them or?
FF Affiliate
Cant mis then only 2 Black looking Fuses ( not fuses ) in that box to the right
Those Ground wires are the grounds to the ECU / Computer make sure there clean
1 - 4 of 4 Posts
