I absolutely would install a new clutch disk and pressure plate, is the seal leaking profusely? maybe there is oil on the clutch? I also would replace the slave if it is an internal one which I believe it is. You want to replace any seals that you can on the tranny......the $1,100 to drop the tranny and swap out the seal sounds like the Stealer-ship price but I am only guessing........the seal probably cost $30 and the rest is labor...........I think you have a timing chain but i always wondered that if you needed a timing belt and a clutch if it is possible to remove the engine and leave the tranny in the car?I'm having a shop replace my rear main seal on my ST (duratec 23). Should I have them replace anything else (clutch, flywheel, axle seals) while they have it apart?
BTW...they quoted $1100 to do the rear main seal. Any thoughts?
I gave it some thought and did a little research........they are screwing you...my guess is it is a 6 hour job.........I would find someone else http://www.youtube.com/watch?v=jN1Z_xsmae0Pizza...check
Beer...check
Buddies...check
Garage and time...
Thanks for the replies. I wish I had the time to do this myself, but I'm traveling a lot for work right now. The car has just under 120k on it. The shop has a lot of good reviews and charges $80/hr.
there is no way ford will be carrying 12.5 hours to replace the seal......,,,,,I would do some more research on it.........I think you might have a duel mass flywheel......they are expensive and I don't think they can be turned........I would make sure that the flywheel was not the cause of the leak?Even if parts and fluids are about $100, the $1000 for labor equates to 12.5 hours. I'm having the dealership quote it for a reference point.
The leak started as a slow drip in the spring. It has become a pretty steady drip now.
the more I think about it I can not imagine a reputable shop not even suggesting to replace the disk if they were going to drop a manual tranny to replace the rear main seal............I would stay away from them...IMHO12.5 hour is kinda high but really not bad. I have never pulled a focus transmission. But, i did just pull the tranny on a 2008 SAAB. i had it out in just over 4 hours i imagine i'll have it back together in another 4. that gives them an estimated 4 hours for extras, get a clutch and make sure there is no extra labor, it comes apart anyway.
the only time a flywheel can cause a leak is if its a blow out dual mass, you would notice an severe vibration if the flywheel was blown. All the bad dual mass fly wheels i have seen leaked oil then vibrated severely.
