1 - 11 of 11 Posts
I'm in the process of installing rear camber arms and toe arms and I
had a seized bolt on the passenger side toe arm. I cut the bolt and now
I am left with part of it still in the nut and I cannot turn it with pliers
or even vice grips.
Would a bolt extraction kit work in my situation?
Does anyone have one they'd recommend?
Here are the pics:
Tips and advice would be greatly appreciated.[thumb]
BACON?
one option is find a set of twist sockets. similar to these, but shallow. http://buy1.snapon.com/catalog/item.asp?item_ID=65957&group_ID=11918.
or heat it then try the vise grips,
or left handed drill bit with an easy outhttp://buy1.snapon.com/catalog/item.asp?P65=&tool=all&item_ID=10474&group_ID=1261&store=&dir=catalog. there are tons of tools available for broken bolts. it sucks but the easiest way will require buying tools.
OR if you own a welder you could attempt to weld a nut on to the bolt. Just be careful.
oh, and if possible i would try to make that bolt come out the way it would if it was whole. the threads look trashed. no need to risk the threads in the nut.
i must have mis read before. I use this http://buy1.snapon.com/catalog/item.asp?item_ID=62659&group_ID=1254 but i think that is to much money to use one time.
Thanks! I will be taking the bolt out the way it would have came out for sure.
Do you think a twist socket would work on the short side where I cut it?
Just cut the nut off and use a normal bolt w/out captured nut. I've had to do it a couple times on the suspensions of a couple foci. Works fine, no problems.
Standard bolt is 12mm, 1.75 pitch, about 70mm long.
My sawzall won't fit in there to cut the nut and I don't have any other tools to do that.
I'd rather keep that nut on there anyway.
coffee, have some
Can you get your hands on a dremel? I would bring one out to you but I'm going to be pretty busy after work the next couple of days :(
If you're in dire need and wanted to meet me somewhere i could do that too?
Or...get a cut off wheel attachment for a drill from Home Depot or Lowes?
I agree about just cutting it off, I did on both of mine when I installed toe arms. No issues since, I think it's welded just to make installation easier. I hate those nuts.
Boost Addict
I tried the bold extractor sockets on time....didn't work. Did you soak it with penetrating lubricant?
Discussion Starter #9
Its been sprayed with PB blaster multiple times/days.
I'm going to just get a cut off wheel and grind the nut off and get a new nut for it.
Discussion Starter #11
I ended up grinding off the nut and replaced it with a new nut.
Worked out great!
1 - 11 of 11 Posts
