The rear Control Blade suspension is still the same, so it stands to reason this would be quite feasible, though I have no clue how easy it would be. You should do it first.[thumb]the 2012 seems to have the same frame too. can someone say 5 lug swap?
Exactly as Ford intended. This is the whole design intent of a refresh -- to have improve the vehicle sales with the smallest investment possible to make the biggest impression -- hence the emphasis on sheet metal changes.Yeah i would consider all the stuff they changed including the engine a pretty big change. oh well.
On a different note, it the rear Control Blade suspension that make these car's handle like they do & the firm steering rack too. Work's great on my GEN. 1.5 model!The rear Control Blade suspension is still the same, so it stands to reason this would be quite feasible, though I have no clue how easy it would be. You should do it first.[thumb]
I'm in the school of thought that calls the 05-07 "Gen. 1.5" as well.
What do you mean not a change? Its not even mounted in the car the same as the zetecExactly as Ford intended. This is the whole design intent of a refresh -- to have improve the vehicle sales with the smallest investment possible to make the biggest impression -- hence the emphasis on sheet metal changes.
The engine wasn't so much change as... an elimination of a host of engine options.
There's an interesting brochure Ford put out that elaborates on the exact changes made in 2005.
Still... a refresh.
