1 - 20 of 35 Posts
Crower has recently changed the part #'s on their camshaft grinds, here is an update and a look at their before and after part #'s.
Camshaft/Intake lift/Exhaust lift/Int Duration/Exh Duration/Intake @.050/Exhaust @.050
Old crower cams
Crower stage 1 .374 .374 271 271 220 220
Crower stage 2 .374 .374 271 276 220 228
Crower stage 3 .393 .413 276 287 228 236
Crower stage 4 .413 .433 284 296 236 244
New crower cams
Crower stage 1 .374 .374 271 276 220 228
Crower stage 2 .393 .413 276 287 228 236
Crower stage 3 .413 .433 284 296 236 244
Just so everyone knows and doesn't get confused.
thanks for the info, are all of the vendors going to go by this now for all of their cams? cus i dont want to order stage 3s and get stage 4s....or do i?
Well its commonly known about the change.
For example, the old crower stage 2 part # was 62502, the new # is 62502-2
Whats weird is that crowers site hasn't been updated.
thats what i was wondering, seems to me like they just tossed the old stage ones and would have kept the old part #s and left it out, guess that would be too easy
Discussion Starter · #6 ·
The clearances should always be checked, I have run into few problems with them. It is better to be sure.
These numbers are lift and duration numbers. Lift is how far it opens and duration is how many degrees it stays open. 360 is 1 full turn so 250 duration means 250 degrees of 360 is how long it is open.
The Ford Racing (Crane) are a little milder than the crower but the Cat and the Crower cams are very similar. We handle and have tuned all of these cams. We will be dealing with the Comp cams soon and will have pretty much every cam brand available. I would like to see ther power they make.
so what mods are needed to make the new stage 2 cams to work
and what about the new stage 1 cams
thanks
Alright maybe im confused...But are the crower stage1 cams stage 2 now...Did they just get rid of the stage 1 all together... Or did they just upgrade everything a little bit..
Is $275 a good price for slightly used Crower stage 2 old grind stage 1 new grind cams and does anyone know if they will require shims.
Discussion Starter · #13 ·
Shimming is required on many camshafts available for the focus, its not hard to do. Though, if you don't know what your doing then you need to have a professional do it.
Shimming for overheadcams is done by placing a certin size spacer between the valve stem cap and the cam.
hey yel900rr
the cat cams you sell are the a direct fit or they require some work to and are they more aggressive then the ford cams?
thanks
1 - 20 of 35 Posts
