1 - 13 of 13 Posts
I am installing crower stage one cams in my Focus and I've run into a bit of a problem. All of my valve clearance reads are to low. All readings were in spec with the factory cams. Six of the eight intake valves have 0 clearance. I don't think Ford makes small enough tappets to bring the clearance into spec.. These cams should be a simple drop in since crower says they have a factory 1.425" base circle. Has anyone run into this problem?
AKA Toyotech
i have stage 1's and just had right under spec clearence on two or the lobes, last i checked ford does have the buckets for you, best of luck. (you could always be like some people and grind away. lol)
They make them, folks with crower stage 3's have made clearance with ford shims so you shouldn't have a problem.
Discussion Starter · #4 ·
OK, Ford doesn't make a tappet small enough for one of the lobes, I would only have .002" clearance. Besides, I'm not spending another $100 on tappets when Crower says the base circle is the same as factory; IT'S NOT! I measured my factory cam and the base circle is 1.420". The Crower is 1.429", causing .004 - .005" less valve clearance. I took it back were I bought it and checked another Crower and it was the same. I checked a Crane cam and it has a base circle of 1.420", the same as the stock cam. I installed it and all valve clearances are perfect! Anyone out there that has "dropped in" a Crower cam without checking valve clearance many want to pull the valve cover and check them. Intake clearance (Ford Spec) is .004 - .007" (.11 - .18 mm) Exhaust is .010 - .013" (.27 - .34 mm).
Interesting, there are like 5k cars with crower cams and no problems from what I have heard.
if yours are that far off then you will have to have a machine shop make you some.
Check your e-mail focaltech i sent you those turbo pics and info i had. that we were disscussing
AKA Toyotech
other mods, be really impressive to gain 30-40whp from just cams
its be a gift from christ to get that for 300$.
1 - 13 of 13 Posts
