or gnomes...dannybohhy said:ghosts...
Gremlins?bacarl said:or gnomes...
yes... a predator was used. No DTC codes other than the p1000 which from what I've read is normal and will not cause a check engine light.penguin said:If the light is on, there should be codes. I assume you are trying to read the codes with a real OBD-II code reader, and not that that odometer trick?
