I'm at my wit's end on this one, and from reading some of these threads you guys really seem to know what you're talking about.
My 2000 plain-no-frills-out-of-the-box Focus went from a great car to a lemon in a very short time. Since the whole car is computer controlled, and trouble codes can only tell you so much, I got a PCM interface and software to talk to the PCM from my laptop. I can't find a button that says "Skip all this technical stuff and just tell me what's wrong with my car" so I'll have to do it the hard way and think a little. Bummer.
The problem I'm experiencing is very bad performance on acceleration. By bad performance I mean that power goes to almost zero, the car stutters, bogs down, jolts and starts throwing up cylinder misfire trouble codes. Unfortunately, it's not any single cylinder, and it's even tossed up a P0300 (Random misfire) a time or two.
I plugged in my computer and immediately saw the problem. Ok, I didn't see the problem, but I saw the manifestations of the problem. If I saw the problem, I'd have fixed it already. Sitting in the driveway, my TPS reads 20.4%. WOT reads 93.3%. This seems a little weird, so I plugged the computer into my wife's truck for comparison and her TPS shows 0% when you're not pushing the pedal and 100% at WOT. I immediately suspected by TPS, and being only $20 I replaced it. No change in performance.
I took it out on the road and recorded all parameters under various conditions. Gentle acceleration actually works, but when I start to press the pedal a little I immediately notice the timing advance drop from 20-30 down to around 5-10. This explains the very poor acceleration, but since the ignition timing is controlled by the PCM there's nothing to adjust. Either the PCM is bad or (more likely) it's getting a bad input from something and is trying to compensate.
The diagnostics also shows crazy numbers for my engine load and short term fuel trim. Engine load is supposedly calculated based on air flow divided by peak air flow, but there's a reasonable correlation between throttle position and air flow readings. If I press the accelerator, air flow increases. This is what I would expect since I'm opening the butterfly on the throttle body and letting more air in.
I tested the voltages on the TPS both at the sensor and at the PCM. At idle (ignition on, engine off) I get 1.00 volts and at WOT I get 4.77 volts. Reference voltage is 4.97 volts. Hmmm. 1.00 / 4.97 is 20.3%, which is what my TPS reads at idle. 4.77 . 4.97 = 93.3%, which is what my TPS reads at WOT. It looks like the PCM is showing absolute values instead of adjusting for actual range.
Finally, here's my question. Does anyone know what inputs the PCM uses to calculate timing advance? I'm suspecting my MAF sensor, but it has a reasonable correlation with RPM. Not as good as I'd expect, but nothing crazy that would indicate a really bad sensor, and certainly nothing that would cause a 50% drop in timing advance at 30% throttle (adjusted, so that's really 30% throttle).
Thanks in advance for your help, and sorry about the long post. There's just so much info to consider, it's hard to ask a question without giving background. I still think I'm leaving out a bunch of info. I'll check for replies after church.
Thanks!
Thanks!
