Car was running fine the other night our temps dropped to below zero for a few days, started it up the next day when it was 2 degrees out started fine... then after a minute of sitting idle it conked out like you shut it off and now it won't start.
I've tried starting it, you can hear the starter run, looking at the engine while someone else starts it the belt moves and the pulleys turn fine.
Turn the key you can hear the fuel pump do something.
took a fuel line off a rail turned the key to run without the start and fuel flows out of the line like it should when pressurizing the rails for a start.
Changed the oil to look for metal fragments, nothing, all new oil now.
Checked the cam shaft sensor, it's working fine (haven't checked the crank shaft sensor)
battery was 10.8 volts when sitting idle, seemed low it was a high amp cranking battery though, but tried jumping it and charging it to make sure.. battery charges fine jumping it made the starter seem stronger on key turn but still no engine start.
no engine error codes when I put the scanner on the ODB-II port.
didn't pull the engine cover to look at the timing chain yet (i assume it was a chain in this 2.0 L engine)..
what else could be wrong to look at? Could the engine somehow of flooded or flooded trying to start it in the cold? If so does the focus have a flood clear mode like some cars do where you crank it when the gas pedal is pressed?
The car is a 2006 Ford Focus ZX4 SE with 50,000k miles on it
Edit: Can you see the cam shaft through the oil fill port on this car? If so I could easily tell if the timing chain broke or not.. I'm not at it right now to look
