my dad bought a 01 focus zx3 for $700 . drove it a week then it had a horrible miss fire. could unplug spark plugs 1 and 4 and engine would not sound any different. which means it was running on just cylinders 2 and 3. so i bought a coil plugs and wire. still no spark. the plug that plugs into the coil has 12 volts at center pin green/blue and black/orange wire.and no power out of the black/green wire which is also on the coil plug. so i went to the pcm disconnected the plug. went to pin #56 which is the black/green wire that is on the coil plug and tested that the wire by send 12.5 volts from the battery though it and tested 12.5v at the pcm plug on pin #56. tested crank sensor which checked out good. tested cam sensor which also check out good.
and now my dad just told me today the kid he bought the focas from had to get a new key. and that he bought a whole ignition threw ebay that cam with a key and the chip in it. i was wondering how could you test if its in some kind of security mode. just make me wounder if this would cause the ignition issue?
any help would be appreciated
