1 - 7 of 7 Posts
So I've fixed the leak into my passenger side floor. Now it's time for cleanup, I've taken my carpet shampooer thing that sucks up water and sucked out a majority of the water. However there is still some left underneath the carpet/padding.
I have a dehumidifier that I was thinking about hooking up in the car as that should remove all moisture from inside my car.
Good idea or no?
Yeah only problem with that is I live in Washington State, and its been raining for the past week or so and it doesn't plan on stopping anytime soon so I don't think leaving the windows open is a good idea unless I plan on cleaning more water up haha.
The de-humidifier idea will work. It just takes longer than sitting it in the sun with the doors open, propping up the carpet, and using fans.
If you run the de-humidifier for a long time, till everything is totally dry, you may avoid any musty smell. Outside in wet weather will make this a lengthy process...
1 - 7 of 7 Posts
