1 - 3 of 3 Posts
1st question- kinda a dumb question but I will go ahead and ask. Will a one touch window relay work for the passenger side window? I don't see why it won't work but I need some input
2nd- Will a euro headlight switch work with the USDM connectors? I noticed it had a drl and an adjustment for drl... Looked kinda neat
Hopefully someone can help me out... Brent
Not sure about the headlight switch, but i don't think the relay would work properly. You switch for the passenger side is not a double step switch like the drivers side is. Meaning if you rigged it where it did actualy work then it would always be one touch down and you couldn't stop it at a certia point with have to go back up after it went all the way down.
I can live with it not stopping at a certain point, I only drive with windows all the way up or all the way down. It technically will work with the proper switch is what your saying?? I might just buy the right switch and try it
1 - 3 of 3 Posts
