Heres a question for all you Vet's
what I have is the following
2001 Focus SE Wagon (Zetec)
When I purchased it the engine was unopened and untouched the mechanic who I purchased it from immediately wrote the engine off as blown
what I have currently come to conclude is the following
-Timing belt is stripped
-cooling system failed (unknown if the engine overheated)
-0 coolant in the engine (not even in lower rad hose)
-TPS tested good for voltage but its the TSB'd one
-PCV tube is holed and collasped (a chunk fell off when I touched it)
-Oil is clean and new
-Fuel tank is 93% full of Premium
-Powersteering fluid is full and clean
-Transmission fluid is clean, I am unsure of its level due to the engine must be running to check)
Engine cranks harshly but does manage to fire (as in sputter, not running) even with no timing belt
Battery is at 13.37 volts
heres a vid of the engine cranking over (I havn't cranked this engine over in over a week so I was surprise with the sputter that quick)
Also- Ive already made plans and going to pickup a Zetec off a car that was recently written off from a member on the forums.. Im asking this cuz if its just acting stupid and will in fact run I will offer it to the FF Members as a project engine real cheap
