1 - 2 of 2 Posts
I was wonder if anyone has a cooling system diagram for a 2000 Focus SE (the wagon). I have a coolant leak I am trying to pinpoint. I had a pressure test done and was told the thermostat housing was leaking, there is a minor leak, residue. From what I discovered online the thermostat housing is on the opposite side of my leak (near the battery). The problem I have with the information discovered with my pressure test is that the leak I keep seeing on the ground is below the pulleys and obviously the below the water pump. I just want to make sure I am looking at the right parts in the right area. I do not want to confuse the thermostat housing for a water outlet. Thank you.
Discussion Starter #2
I just spoke with mechanic that checkout my Focus and he confirmed it is the thermostat housing. My question now is; is it possible for a leak to run off to the opposite side on the engine and/or leak?
1 - 2 of 2 Posts
